Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2981 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4570 Views
  • 1 replies
  • 16 Helpful votes
Is Port Link Aggregation simple to do with the GUI of the Switch or does it require command line interaction?  Have not purchased yet, but, from reviews it sounds like it is a little more simple to setup via the Web Browser then the catalyst switches...
I have a SG300-20 at one of our buildings running in layer 3 mode.  Ever since I moved over to running as a DHCP replay, we are fighting with high tcam utilization.  I've moved the maximum up to 386 but still have to reboot it once every couple of da...
I have a 24 SG 300 POE. On port 22,23 and 24 I have connected access points. The ports are configured trunk with VLAN 400 native and and vlan 300. Trying to create VLAN 400 employee-wireless and 300 for Guest. The issue is the AP are not getting IP a...
jgranda by Level 1
  • 540 Views
  • 3 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
