Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3444 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4994 Views
  • 1 replies
  • 16 Helpful votes
I have a problem with the cisco switch model SG220-50 EU. I use on the switch VLANs, and trunks, but every trunks have problem with oversize packet. Switch is Connect with MikroTik x86(metal port 49,50), next switch SG220-26, and wireless transport ...
Stenli323 by Level 1
  • 1007 Views
  • 0 replies
Hi all, A quick question, can I use all 4 SFP+ ports as uplinks or are some ports only available for stacking? I am hoping to connect 2x HP servers and a Qnap array using SFP+ for which I need at least 3 uplink ports and the SG500X-24 fits nicely in...
I just noticed a new FW for the Sx-300's and 500's which shows very little has changed in the release notes.  Now what bugs me is trying to determine what the current boot should be.  The details under the current FW doesn't list the proper boot vers...
viningele by Level 3
  • 506 Views
  • 1 replies
Hello i have purchased sf300-48p and start its configuration very well but i face a problem so you can help me in this one i have created 3 vlan vlan 1 default   interface ip  192.168.1.254 /24  vlan 16   interface ip  172.16.16.16 /24 vlan 23   inte...
I currently have a Comcast Cisco Gateway DPC3939B connected to the GE1 port on my SF200-48 switch. I cannot attach to the management on the DPC3939B through the network without the management site failing to load. Does anyone know if I should be chan...
ihmtech01 by Level 1
  • 540 Views
  • 1 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
