Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3444 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4990 Views
  • 1 replies
  • 16 Helpful votes
I have a Cisco SG300-28P Managed Switch.  After repeated attempts to reset the unit, I discovered that the reset switch had broken.  There were two small pieces that appear to be an internal piece (the part that shorts the pins) and what appears to b...
bobd00001 by Level 1
  • 1183 Views
  • 3 replies
OK, clearly I am missing something, but this is my first time using both VLANs and Voice. I have read so much documentation that my eyes are glazing over. Scenario: Cisco SG220-50P feeding a Sonicwall TZ600 firewall and then out to the internet throu...
BADBADDOG by Level 1
  • 654 Views
  • 1 replies
I'm having problems with my network. We use a single SG102-24 Cisco switch with about 16 ports utilized. The entire network is wired with CAT6 cables. One computer was constantly unable to save files across the network to either of 2 Ready NAS hard d...
Hello, First of all, i'm sorry for my poor EnglishI recently received 4 SG500X-48 Switch and 4 SG500XG-8F8T for made a stack whit them. My problem is, i cann't upgrade the boot on my  SG500X-48.They configuration are:SW Version: 1.3.0.62Boot Version:...
Renduke02 by Level 1
  • 1259 Views
  • 2 replies
I need to install a SF100-24 switch into 1RU of a 19 inch rack. I do not have the rack mounting ears as this switch resides on a table.Does anyone know where I can obtain some SF 100-24 ears at? I suspect they will have to be about four inches in len...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
