Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3605 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5286 Views
  • 1 replies
  • 16 Helpful votes
Hi, I have various issues with my 3 switches. Switch 1 ====>connected on stp to core switch on port 49 (trunk and uplink enabled)                           Connected on stp to switch 2 on port 50 (trunk and uplink enabled)Issue switch 1: Connection r...
I have a question about the SG100D switches series. My network is as following.It starts with a Glasfiber modem --> Draytek Vigor modem. In the modem I have plugged in 3 Cisco SG100D switches, two of them with 5 ports and one of them with 8 ports.One...
giel00001 by Level 1
  • 1171 Views
  • 1 replies
I have a Cisco SG300-28P Managed Switch.  After repeated attempts to reset the unit, I discovered that the reset switch had broken.  There were two small pieces that appear to be an internal piece (the part that shorts the pins) and what appears to b...
bobd00001 by Level 1
  • 1222 Views
  • 3 replies
OK, clearly I am missing something, but this is my first time using both VLANs and Voice. I have read so much documentation that my eyes are glazing over. Scenario: Cisco SG220-50P feeding a Sonicwall TZ600 firewall and then out to the internet throu...
BADBADDOG by Level 1
  • 661 Views
  • 1 replies
I'm having problems with my network. We use a single SG102-24 Cisco switch with about 16 ports utilized. The entire network is wired with CAT6 cables. One computer was constantly unable to save files across the network to either of 2 Ready NAS hard d...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
