Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board from June 18th - July 18th. These dates are subject to change pending progress. This in...
CoreyP319 by Cisco Employee
  • 586 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5545 Views
  • 1 replies
  • 16 Helpful votes
I have a question about the SG100D switches series. My network is as following.It starts with a Glasfiber modem --> Draytek Vigor modem. In the modem I have plugged in 3 Cisco SG100D switches, two of them with 5 ports and one of them with 8 ports.One...
giel00001 by Level 1
  • 1185 Views
  • 1 replies
I have a Cisco SG300-28P Managed Switch.  After repeated attempts to reset the unit, I discovered that the reset switch had broken.  There were two small pieces that appear to be an internal piece (the part that shorts the pins) and what appears to b...
bobd00001 by Level 1
  • 1259 Views
  • 3 replies
Hello,I have a few SG200s, mostly one at each building.  There is one that I suddenly can't log into - "invalid user name or password"*.  With no COM port, it sounds like I don't have many options other than factory reset.   Right?  The basic re-conf...
Hi all, I am trying to setup a VLAN on my network which will be for servers and other resources (not clients) and I am having quite a bit of trouble getting it to work. I have setup VLANs before with Dell PowerConnect and 3Com switches but we have si...
dzilla000 by Level 1
  • 4803 Views
  • 6 replies
OK, clearly I am missing something, but this is my first time using both VLANs and Voice. I have read so much documentation that my eyes are glazing over. Scenario: Cisco SG220-50P feeding a Sonicwall TZ600 firewall and then out to the internet throu...
BADBADDOG by Level 1
  • 673 Views
  • 1 replies
I'm having problems with my network. We use a single SG102-24 Cisco switch with about 16 ports utilized. The entire network is wired with CAT6 cables. One computer was constantly unable to save files across the network to either of 2 Ready NAS hard d...
I recently setup a small domain for my business and when trying to access the web interface for the SG200 from a client that is in the domain, the switch configuration website has the standard blue background and two input fields, but I can't get any...
Hello,I have an SG200-08 and can't get NTP to work.  The relevant lines of my configuration are below:sntp client mode unicastsntp unicast client poll-interval 16sntp server pool.ntp.org enableclock summer-time recurring USA zone EDTclock timezone -5...
niuoras01 by Level 1
  • 1568 Views
  • 3 replies
Hello, First of all, i'm sorry for my poor EnglishI recently received 4 SG500X-48 Switch and 4 SG500XG-8F8T for made a stack whit them. My problem is, i cann't upgrade the boot on my  SG500X-48.They configuration are:SW Version: 1.3.0.62Boot Version:...
Renduke02 by Level 1
  • 1300 Views
  • 2 replies
I need to install a SF100-24 switch into 1RU of a 19 inch rack. I do not have the rack mounting ears as this switch resides on a table.Does anyone know where I can obtain some SF 100-24 ears at? I suspect they will have to be about four inches in len...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
