Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2983 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4571 Views
  • 1 replies
  • 16 Helpful votes
For whatever reason I can telnet from another switch to the SG300 switch but not directly to the switch. I also can't access the web interface or ping the switch. Any help would be appreciated. Here is the running configconfig-file-headerWasteWaterSG...
Hello. I am having two problems with internal web servers and VLANs. Here is a description of the existing infrastructure: Business cable modem with a block of static IPs. These IPs are for example only and are not my current set, just an ourdated se...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
