Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2980 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4569 Views
  • 1 replies
  • 16 Helpful votes
I'm moving from a WS-C2960-24PC-L to a SG300-24P.  Most things are working ok.  I'm seeing one thing that isn't coming over as expected, but it might be a syntax problem.  I have two ports that are setup on two VLANs.  Here is the port config from th...
I have been having issues for a long time with the SG500X units. I keep getting many "Drop Events", or dropped packets (as seen in the attachment). There are no real "errors" or issues that I can see otherwise. I have 2 stacked SG500X-48 port switche...
Hi, I have a two new cisco switchesfirst switch: SG300-28PSecond switch: SF300-48P N.b: My Gateway is the firewall ip 10.0.0.1/16i am trying to configure two vlans with the same gateway 1st vlan for VOIP (Polycom) : ip range 10.0.10.0/242nd vlan for ...
Hello,I'm trying to setup following scenario which is working with no issue on netgear switches (like GS108) but I have not been able to get it to work on Cisco SG-200I did quite a bit of reading here on many post but nothing seems to work. Setup:P1 ...
marcin by Level 1
  • 13991 Views
  • 8 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
