Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2599 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4127 Views
  • 1 replies
  • 16 Helpful votes
Hi,Does tha SG200 need any out of the box hardening, or special security configutations to run safely on the network?  For the question, please assume that there is a cable modem, whicn connects to a router (w/DHCP), which connects to the switch, and...
Resolved! DHCP Problem
I have an SG300.   I have two ports on vlan 20 which is subnet 172.20.20.0/24.   The laptop I have needs to get it's DHCP address from the device that is connected to one of the two ports on vlan 20.   However the laptop that is connected to one of t...
-----------------------------------------------------------------------------Model: Linksys SRW248G4 sw.        Issues:-----------------------------------------------------------------------------1) [edited]One is NOT able to add a port to many untag...
Resolved! SMB configuration
Hello I'm tying to validate this SMB configuration."Core"in stack configuration ring2 SG500 24 ports 1 SG500 48 ports3 SFP-H10GB-CU1M= for 5G stack5 MGBSX1 (uplink to access)1 copper uplink port (combo) link to CLC"Access"3 SG300 48 ports2 SG300 24 p...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
