Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board from June 18th - July 18th. These dates are subject to change pending progress. This in...
CoreyP319 by Cisco Employee
  • 537 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5517 Views
  • 1 replies
  • 16 Helpful votes
Resolved! Radius on SF200-24
Just got a SF200-24 (SLM224GT) in to configure for a small office. According to the product manual and the web gui it should support RADIUS authentication. The switch is running the latest firmware 1.3.5.58. Full logging including debug is enabled.Ra...
thni by Level 1
  • 2060 Views
  • 2 replies
HiCan anyone help me to setup this network..... i cant get the VLAN 50 and 100 to access internet, i is it any wizard for dummies anywere? I put in a drawing of my network.. pls ask if its anyting info/settings i need to check..Thx anyway
firmapost by Level 1
  • 7658 Views
  • 12 replies
  Hi,I have 2 SG300-10mp switches which i am trying to create a link redundancy for over the two fibre ports.On the web interface when i go into the LAG settings ports g9 and g10 which are the fibre ones don't show up.How do i create the link aggrega...
hi,What is the best way to connect switch together (with 2960 switch)..cross or stright cable...up/down or normal port ?WAN ----Router 1 --- -SW1 ---- SW2                                  |                                  |                          ...
t80243280 by Level 1
  • 832 Views
  • 1 replies
Hello,I want to setup VLAN to separate attached devices (will use a VLAN capabel WLAN accesspoint).I am looking at the Cisco Small business products.Like this: SG200-08PThis is my goal:3 VLAN's: Internal, External, GuestDevices connected to Internal ...
samboman1 by Level 1
  • 1025 Views
  • 3 replies
We need to "reset" a SG200-08P switch back to the factory default settings and noted the "Quick Start Guide" implies the "Reset" button next to the power button doesn't exist and refers the user to the "Cisco Small Business Smart Switch Administratio...
kenbucknam by Level 1
  • 110623 Views
  • 12 replies
Hi all,I have recently received a SG200-26P poe switch to potentially upgrade the office switch.So on first boot - it went through its post, got a solid green light.I then connected my PC to the first port to try and configure it via the web interfac...
Probably more pressing information than what is below, but if I have a SG300 in layer 3 mode, can it handle multiple DHCP scopes using one nic out of the server, or do I need to add a router.            I have two SG300's that I'm working with and I ...
I am trying to get multicast across VLANs working on my SG500 and since it doesn't have PIM, I think the Multicast-TV option can work.However, now my clients are getting switched to the Multicast-TV VLAN instead of the regular VLAN they are assigned....
DJX995 by Level 3
  • 1967 Views
  • 6 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
