Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2669 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4196 Views
  • 1 replies
  • 16 Helpful votes
Hi everyone,I've got some trouble with the igmp snooping in my switches. My main router operates only with igmp v2. The switches igmp snooping table entries are toggling to igmp v3 sometimes (mostly after attaching new devices) and there seems no way...
Good day !Does it work on cisco SG- 300 dhcp relay forwarding?In the following example, one client port , 10 uplink.Need to query the DHCP server went 3 vlan.The current configuration of the device : cisco # sh runconfig-file-headerciscov1.3.0.62 / R...
Hi all,I have a switch SG500 28G POE stackable. See my config below in my switch and this is the corect configuration with no issue.interface gigabitethernet1/1/2 description Dlink-SW-GSD-4-IPphones-No5 switchport trunk allowed vlan add 20,440This po...
Hi all,Does anyone know Cisco Small Business 300 Series Managed Switch support dhcp server service? I have a SF300-24P but i cant see that option to configure dhcp server. If any 300 series switch supports dhcp server then please let me know.Kind Reg...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
