Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2742 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4285 Views
  • 1 replies
  • 16 Helpful votes
Hi all,Does anyone know Cisco Small Business 300 Series Managed Switch support dhcp server service? I have a SF300-24P but i cant see that option to configure dhcp server. If any 300 series switch supports dhcp server then please let me know.Kind Reg...
Hi,i have a question about the max number of sfp ports available on the SG500X-24 Switch. I need to configure a Stack with 2 SG500X-24 units: can i use 5G ports and have 4 SFP as network ports. In the quick start guide i read that i can use i couple ...
I am having issues with PXE getting a DHCP through this switch.   It seems I need to set the IP Helper address in the switch but I am not sure where to set this any help would be great?I am getting the following error:PXE-E51: No DHCP or proxyDHCP of...
Hi , for some reason, i cannot access the switch via the web interface. i reset the switch to factory settings , and the same thing happens. i tried to access the switch via a diferrent pc and still the same, i would appreciate some help on this.
ISHAL by Level 1
  • 1167 Views
  • 4 replies
Resolved! dhcp sg300 vlan
Okay. I have two scopes for two vlans configured on the sg300. When I put my laptop in vlan 1 I get an ip from 192.168.0.0/24. I then release the ip, I put the port my laptop is in into vlan 20 and try to renew to get an ip from 172.20.20.0/24 subnet...
Hi,I have an SG300-10P but it doesn't seem to working as expected, so I need some help getting the configuraiton correct. I have a workstation on a vlan (998) but it can't ping a host on the internet (8.8.8.8) but from the switch I can ping 8.8.8.8. ...
I am trying to leverage a couple of SG200 for a small office area.    It will be downstream from a 2960 layer 2 switch, connected to a trunk enabled port on the 2960.   The topology looks like this:/PC DESKTOP/====/IPPHONE (7962)/======/SG200/======/...
brunellej by Level 1
  • 858 Views
  • 1 replies
