Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2601 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4129 Views
  • 1 replies
  • 16 Helpful votes
I have the following setup using two SF302-08P PoE switches: 1st floor=========Switch #1 <-------> private network          <-------> public network2nd floor=========Switch #2 <-------> private network            ....    public network (visible but d...
Resolved! SLM2048
Am using the SLM 2048 as my core switch in a small environment,for distribution switch I have ESW520, SRW2048,catalyst 2960 and another SLM2048.Each of the distribution switches has a single link to the core.Prior to deployment I configured a managem...
Hey,I'm redo-ing my entire network infrastructure in my small business and I'm completely crossed on which products to buy. I need 20-25 ethernet ports + WiFi. I don't need any special features. I have two Comcast business class internet modems with ...
henry by Level 1
  • 1198 Views
  • 3 replies
Hi,I have a brand new SG500-28P sitting on my desk. I am having a very weird problem. I hope someone can advice me.The swtich is configured and going to operate in L3 mode. All ports are still assigned to the default VLAN ID 1. I have created several...
I would like to cut the noise from my SG200-26P. Any fan suggestions to replace the stock fan with?Can anyone tell me the size of the original so I can look for an alternative?Regards ChrisSent from Cisco Technical Support iPad App
Hello,We have netwotk 192.168.1.0 with the default gateway 192.168.1.1 (Juniper Netscreen Firewall). I bought the switch SG500x and want to use as backbone switch. It will be placed between the Juniper and other layer 2 switches.I want to use this sw...
nvong by Level 1
  • 2434 Views
  • 3 replies
                   I owe a SG200 26 port switch and it works fine so far.Amacintosh computer (mountain lion) has been added to the wired net. Everything works fine t first, but there's a sudden disconnection issue.It seems that the macintosh computer...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
