Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3514 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5188 Views
  • 1 replies
  • 16 Helpful votes
Hi,I had connected a computer and NTP to the SG500. i had successfullly sync the internet time on the computer. but when i type 'show clock' on the terminal. The switch did not manage to sync the ntp time. below is my config, am i short of anything e...
reginachh by Level 1
  • 7085 Views
  • 3 replies
I am thinking of buying a SG200-26P switch and have a few questions:Is it possible to disable the PoE function on the 12 PoE ports?I need al the ports but only 6 with PoE.What happens when you connect a non PoE device to a PoE port?Thnx ChrisSent fro...
Good day,during using  switches Linksys sps224g4 faced with the following problem.When the end user is connected in 100 Mbps port of the switch and rtt  more than 10 ms to a remote server, the download speed from server in  one stream does not exceed...
vlutsenko by Level 1
  • 1303 Views
  • 6 replies
Hi,I will like to set auto baud for the SG500. By default its 115200bps.I had tried the following methods:1) switch xxxxx (config)# line console    switch xxxxx (config-line)# autobaud  --------------------> my terminal hangs and print out rubbish2) ...
  • 4395 Views
  • 1 replies
Resolved! POE Switch
Is the SF100D-08P unmanaged POE switch a discontinued model? If so, is there a comparable replacement? I'm looking for a reasonably priced switch to power WAP access points.Sent from Cisco Technical Support iPad App
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
