Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3278 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4825 Views
  • 1 replies
  • 16 Helpful votes
I'm new to vlans and cisco switches and need a bit of direction. I have a my Wifi clients on vlan1 and would like to split them by SSID to vlans 1 & 2. This I can do in my Ubiquiti Unifi controller. All the wifi traffic comes in through one port on t...
ChrisS_NC by Level 1
  • 2847 Views
  • 3 replies
Hello,I  am trying to setup vlans on sf 302 switch and been unsuccesful. My idea  is having 2 separate networks and both connecting to internet192.168.2.0/24  Gaming Network192.168.3.0/24  Work Network Router ( Linkys) connected to port 8 on the swit...
maakri123 by Level 1
  • 1823 Views
  • 4 replies
I have some doubts about the SGE2000 not located in DataSheet or internet:What standard Memory Switch?Do you have any expansion slot?Supports Per VLAN Spanning Tree (PVST)?Supports Port Secure?Supports configuration templates in Gigabit Interfaces?Th...
Hello all,have anyone knowledge if switch Cisco SPS2024 will support CDP protocol in near future? Currently it is not CDP compilant and if there is any neighboring CDP-capable switch connected to it, this switch just broadcasts CDP frames out all oth...
Here is my network layout:I have a cable modem connecting to a Linksys WRT54GL (DDWRT) router. Port 1 on the WRT54GL is connect to port 01 on the SG300-10 switch. On the SG300-10 I've created two Vlans (Vlan 30 & Vlan 40). I assigned ports 3 & 4 on t...
Hello everyone,I have a SG200-26 model but I'm having issues updating the firmware image through GUI and TFTP.  I just recently bought this and used it as a regular switch.  Until I wanted to manage certain ports, I found out the GUI was Linksys bran...
jtuyen888 by Level 1
  • 2816 Views
  • 0 replies
I configured a new SG-200-08 with a static IP. I tried to save the configuration as the startup configuration. After 10 minutes, I restarted the switch. It didn't boot with the new configuration, and returned to the default .254 and default pw. Now I...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
