Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 854 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5640 Views
  • 1 replies
  • 16 Helpful votes
Hi Guys,I am using around 5 sg300's with a lot of Crestron AV kit / touchscreens. About once every couple of months the touchscreens all stop responding. We have found that a reboot of the Cisco switch attached to the touchscreens brings everything b...
phcjpp123 by Level 1
  • 1060 Views
  • 2 replies
For having 3 settopboxes for iptv I have setup vlan 3 for iptv.IGMP snooping is enabled for vlan 3 with the default settings and port 5 (incoming iptv) is enabled as IGMP Mrouter.In the multicast forwarding table vlan 3 is set to filter unregistered....
Hi,I'm  setting up an SG-300 and would like to block some traffic with ACLs.  While I'm  new to cisco products, I was able to easily setup an IP based ACL to restrict  certain IPs from accessing specific ports, but my problem is with applying these ...
I'm trying to get a 300 Series 8 port switch to trunk to my 1140 Access Points.  I"ve added two VLAN's to the AP's and I believe I have them setup properly, I"m having trouble with understanding the gui config on the switch, and how to setup VLAN's a...
Hi,does someone knows if the small business switch SD2008  10/100/1000does handle jumbo frames and up to which length ?I've purchased the switch March 2010I could not find this information on this forum or any product information / data sheetthere is...
rolandwe by Level 1
  • 1524 Views
  • 2 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
