Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2591 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4123 Views
  • 1 replies
  • 16 Helpful votes
Using two 48 port switches with about 40-50 users simultaneously accessing a handful of different flat-file database applications via windows shares, would it make more sense to run these switches both as standalone with a LAG group, or the default s...
Mark^ by Level 1
  • 881 Views
  • 2 replies
Resolved! SG300-10 issue (!)
Hi all,i'm Karim.I have a sg300-10 switch.i update the firmware with the last one. Everything OK.Things are complicated when i create 2 VLAN. ( really 1 VLAN cause the first is native ).So i have the first VLAN with the interface 192.168.1.254ans the...
Ok i am having a problem with ACE rules.I have 5 VLANs, I assign VLANs to its ports and make them all Untagged.I created ACLs and a ACE rules for each ACL, and then assigned to the ports. So what i am trying to do is to deny access to from one port t...
StaismanS by Level 1
  • 1235 Views
  • 5 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
