Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 2971 Views
  • 1 replies
  • 1 Helpful votes
Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Installation Guide - Catalyst 1300 Hardware Installation Guide - Catalyst ...
  • 7516 Views
  • 4 replies
  • 17 Helpful votes
Hello,i try to backup the configuration of the SG250 Switch via http/https.I choose backup and http/http. It start to download a txt file but terminate then with network error.So i see the file running-config.txt with Network error and nothing is dow...
miso by Community Member
  • 1474 Views
  • 6 replies
Hi,I have a CBS350-24P-4T Business switch and I would like to force the PoE on for connected device, a WAN router, claims it does not comply with IEEE-802.3AT, it can be powered by PoE on pins 4,5 and 6,7 on the RJ45 connector. I see in the manual th...
Hello,I've acquired a new Cisco CBS 220 24P 4X and I've an issue to add VLAN into trunk interfaces.  Switch9E8FD1#conf t Switch9E8FD1(config)#int gi24 Switch9E8FD1(config-if)#switchport trunk allowed vlan add 2,3,4,10 Switch9E8FD1(config-if)#end Swit...
cewege by Community Member
  • 2537 Views
  • 6 replies
  • 1 Helpful votes
Hello,We have configured a new CBS250-8T-D Cisco Business 250 series, but we cannot see any TACACS settings for this device, only Radius, while on the specs and the help it's mentioned we can configure TACACS.Do you have any info on this ?Many thanks...
Clem58 by Level 6
  • 1133 Views
  • 2 replies
  • 1 Helpful votes
I have a CBS350-24P-4G  Switch model and I am trying to use the GLC-TE module on the switch port number gi25 - 28 ( 1G-Fiber ) for Copper uplink to another switch. The GLC-TE module is Cisco branded.  The problem is, Scenario-1 When I am using a GLC-...
viv42 by Frequent Visitor
  • 1582 Views
  • 4 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
