Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 2950 Views
  • 1 replies
  • 1 Helpful votes
Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Installation Guide - Catalyst 1300 Hardware Installation Guide - Catalyst ...
  • 7501 Views
  • 4 replies
  • 17 Helpful votes
I recently purchased a SF 100D  5 port switch, that is frustrating me.  I currently have a New dell PC connected through a wall jack to an existing router, and wanted to add an ethernet printer.  When I connect everything to the switch, I can only ge...
We recently purchased a SF 300-48P to replace a Layer 3 3Com switch that died. I've sucessfully put the switch into Layer 3 mode and assigned ip addresses to each of the VLANs but I cannot figure out how to implement routes for those. Here's some inf...
MRP_Chris by Community Member
  • 1668 Views
  • 5 replies
Hi,Mgmt Vlan 1 (default)Data VLan 10 (with access to internet)Is there a way to have a PC attached to a SG300 switch such that it can both access Vlan 10 for data and Vlan 1 for managment ?The PC's port clearly needs to be untagged PVID on vlan 10. I...
phcjpp123 by Community Member
  • 2800 Views
  • 3 replies
Hi,I have a recently purchased 28 port SG300 switch. Everything is working well. Unfortunately there is so much traffic flying around that a 10MB half duplex device is struggling to function as it is overloaded. Removing some of the sources of traffi...
  • 1120 Views
  • 2 replies
I'm sure this is something very basic, but it has me a bit stumpedThis is the config on my SGE2010 switch in Layer 3 mode :-interface port-channel 1description "PCI VLAN1"exitvlan databasevlan 2exitinterface range ethernet 1/g(13-18,37-42)switchport ...
Hi,I keep losing the web interface on our router.I telnet to ports 80/443 and get no response.Restarting the router will bring up the interface, but then the next day I can't gain access.Is there a lock out feature etc? Any other way I can access the...
BBUser011 by Community Member
  • 1273 Views
  • 1 replies
Resolved! SRW2024 no web gui
We have a brand new SRW2024 v1.3. It came with firmware 1.2.2b on it. I can get the login screen, but after authenticating, I don't see any info. I get the html frame information, but the individual frame pages are not displayed. I tried this with Fi...
aaron.quinto by Community Member
  • 56730 Views
  • 32 replies
Dear Cisco!now we have 2 switches: SF300-24on one SF300-24 we config it at layer 3 mode with VLAN configuration same as followingVLAN ID 2 (ports: 2 -6) have ip interface  192.168.2.254/24VLAN ID 3 (ports: 7 - 10) have ip interface  192.168.3.254/24V...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
