Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3019 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4609 Views
  • 1 replies
  • 16 Helpful votes
Hi,Does the new ESW switches support "Cisco Inline Power" Some Service Providers are using CP-7940/60 with SIP image as a service and need switches that automatically detects that the device only support Inline Power..regards/Bjorn
bjjensen by Cisco Employee
  • 2955 Views
  • 1 replies
Hi,i have an SRW2024 here which is not working like it should be.I am not able to configure the IP Adress so that it could be used. I can configure the IP using the console, but it cannot be access or pinged from an attached device.Also the switch it...
I am trying to set up a vlan between buildings I have a srw2024 and a srw2016 switch with fiber between the buildingsthe fibers are on ports 24 (srw2024) and 16 (srw2016) I want to be on vlan 1 and 20.ports 17 (srw2024) and port 7 (srw2016) I want to...
miker2424 by Level 1
  • 3122 Views
  • 1 replies
I have a network with two switches at the core.  One is a SLM 2048 and the other is a 3524.The 3524 is setup with a few Vlans and Voip and switches our Internet connection.  It is only connected to 7940 phones (about 10) and the SLM 2048.The SLM 2048...
pat by Level 1
  • 4151 Views
  • 3 replies
Hi all,has anybody the MIBs from the SRW2016? We are currently running on our lab the cacti server, and I'm interested to create cacti templates with to help small business to implement such open source application to keep track of their devices and ...
jmolinas by Cisco Employee
  • 4055 Views
  • 2 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
