Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 1053 Views
  • 1 replies
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant  - Discover support content and options for your gearSupport page index - Contains ...
  • 2504 Views
  • 1 replies
  • 15 Helpful votes
Hi, Just checking if anyone came across this after upgrading firmware from 1.4.9.4 to 1.4.11.2... The GUI stop loading at Processing Data 80% when the GUI url is a DNS name, but it completes if the URL is it's IP address. Working url ...https://192.1...
boconnel by Beginner
  • 474 Views
  • 0 replies
On firmware 2.5.0.78 as well as on 2.4.5.71 in the GUI after saving the running configuration in the startup configuraton and then restarting the switch, the "save icon with red X" continues to flash, although the configuration has not changed. Teste...
Duber by Beginner
  • 731 Views
  • 1 replies
Hi @All, how do I disable Cisco FindIT on my SG350XG?I dont want to use it at the moment but the connection tries are filling the logs of my other switches. Deleting all device groups did not work as "Default" cant be deleted. Best regards,Hendrik
IFM by Beginner
  • 386 Views
  • 0 replies
Greetings,I have a CISCO SG 300-28 switch, and I was upgrading it's quite old firmware today, first using older major versions of firmwares and boot images and then stpe-by-step using newer major versions.When I've reached the latest firmware version...
JackD-c by Beginner
  • 774 Views
  • 2 replies
My switch always consumes 100% CPU.I see some-one else had a problem alike, I provided my own debug data in the attachment. I can't find the source. There are 2 switches in stack, the amount of traffic isn't high and the CPU is always consuming 100%,...
tfhelp by Beginner
  • 1285 Views
  • 1 replies
After upgrading my SG200-26 switch to 1.4.11.02, I can no longer access it from Chrome (version 77.0.3865.120). I have cleared the cache, history, etc from my browser. I have rebooted both the switch and the computer I am trying to access it from. Th...
dtheese by Beginner
  • 3213 Views
  • 12 replies
