Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 1508 Views
  • 1 replies
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant  - Discover support content and options for your gearSupport page index - Contains ...
  • 2945 Views
  • 1 replies
  • 15 Helpful votes
I have Cisco SG500-52P switches. I have a switch that I have split into 2 VLANS, ports 2-24 are on VLAN 2 and 25-48 are on VLAN 4. The problem is with the VLAN 4 ports, my settings have not changed on the VLAN 4 ports, however, they no longer have ac...
pg1151 by Beginner
  • 569 Views
  • 3 replies
Hello folks.I'm working for an organization that has multiple SG300 switches and 4 VLANs (VLAN10, 20, 30, and 40).I'm at a point where I need to add a new VLAN to the existing network but I've never done it before.I've been able to create a new DHCP ...
danmand by Beginner
  • 782 Views
  • 6 replies
Hi all, have an old SG200 here that was trying to get going for use in a small office. However, booting it up and connecting directly to my laptop, link lights turn off after about 10 seconds. It looks like it will connect, but then it disconnects sh...
Hello,   I configured 3 VLAN on a SG350-28P :        VLAN 1 (192.168.1.0 /24)        +------------------------...
Athena1390 by Beginner
  • 2981 Views
  • 8 replies
Hi have 2 sg300 following config on both gig 10 if:!interface gigabitethernet10description Uplinkchannel-group 1 mode on!interface Port-channel1description Uplinkswitchport trunk allowed vlan add 2-3! when patchcable (2 Pairs, pin 12, 36) is connecte...
kaspar by Beginner
  • 588 Views
  • 3 replies
