Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2976 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4565 Views
  • 1 replies
  • 16 Helpful votes
Bonjour, actuellement j'ai un problème avec la série sg350. j'ai plusieurs VLAN, j'active bien l'igmp comme il se doit mais l'election auto du querier ne marche pas (enfin si mais que dans le vlan 1). l'adresse du querier affiche tout le temps 255.25...
I have never played with Private VLANs.   I have an SG300.  All ports are in VLAN 1.   The switch is connected to the inside interface of my ASA5505.  I have a work laptop and it seems that the IP addresses from my work VPN are showing up as inside m...
Please i need an urgent help. We have a primary number 81026888 in our organisation, when we forward calls from our internal DN to mobile number it alwaays show the primary number 81026888 but now it is showing 81026000, which is a number assigned to...
Hi there, Thanks for reading. I have SG220 switches which are cycling through blocking, learning & forwarding.  We've gone through the building and removed mini switches but the problem continues.  Here's what it's logging (and it repeats throughout ...
Hi! We run SG350X-48 in stack with SG350XG-24F in L3 mode. And we have issue with ARP table building. I dont see any problems in logs but ARP table building is wery slowly. If any host missing in ARP table and i do ping, it takes one, two or sometime...
nameless by Level 1
  • 370 Views
  • 0 replies
Hello, I have a sg300 and suddenly the manage vlan is not working.Please see my config below. the trunk interface is ge25the interface is up and running.  SG300-WAN#show runconfig-file-headerSG300-WANv1.3.0.62 / R750_NIK_1_3_647_260CLI v1.0set system...
it by Level 1
  • 855 Views
  • 0 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
