06-18-2018 08:47 AM - edited 03-21-2019 11:26 AM
This weekend I was updating my switch. Uploded firmware and then set it to Layer 3 mode from ssh:
set system mode router
But alas, the switch wont come back alive.
I've tried 30-30-30 and I see lights flash but only briefly and then nada.
I think I need to go find an antique 9pin cable and do something but try as I might I cannot find any documentation on what to do next.
Can someone take pity help a brother out?
Mark
CluelessInSeattle
Solved! Go to Solution.
06-18-2018 12:02 PM
The default IP address of the switch is 192.168.1.254
Please first change the IP address of your network card to 192.168.1.222
This way you will be in the same network.
Please rate this post or marked as answered to help other Cisco customers.
Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
06-18-2018 09:04 AM
My name is Iliya Gatsev from Cisco Technical Support Team.
The Power LED light is blinking all the time ?
When you connect your PC to port 1 the port light is UP ?
Iliya Gatsev
06-18-2018 09:14 AM
06-18-2018 09:27 AM
Woohoo! The port 1 light finally cam on.
My PC shows an ip address of: 169.254.69.229
Now if I know the default ip of the switch in this configuration....
06-18-2018 12:02 PM
Iliya Gatsev
