Can not ping or telnet into my network, only connect through Putty using Serial
paul_wojo
I have attached paint picture of network devices and wondering why I can't ping or telnet these devices.
Here is my router config:
SG3# sh run
Building configuration...
Current configuration : 6910 bytes
! Last configuration change at 16:12:53 cst Wed May 24 2017
version 15.4
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname SG3
boot-start-marker
boot-end-marker
enable secret 5 $1$V.6M$Km4uy0BEkLJd//F/MeYbo.
enable password 7 04581E041C
aaa new-model
aaa authentication login default enable
aaa session-id common
clock timezone cst -6 0
clock summer-time cst recurring 2 Sun Mar 4:00 2 Sun Nov 4:00
ip dhcp excluded-address 10.201.30.253 10.201.30.254
ip dhcp excluded-address 10.201.15.253 10.201.15.254
ip dhcp excluded-address 10.201.35.253 10.201.35.254
ip dhcp pool data
ip dhcp pool VLAN_DATA-30
 network 10.201.30.0 255.255.255.0
 default-router 10.201.30.254
 lease 0 12
ip dhcp pool VLAN_PHONE-35
 network 10.201.35.0 255.255.255.0
 default-router 10.201.35.254
 lease 0 12
ip dhcp pool VLAN_WIRELESS-15
 network 10.201.15.0 255.255.255.0
 default-router 10.201.15.254
 lease 0 12
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO1941/K9 sn FTX191383R8
username cubs privilege 15 password 7 082943420d1c0b5a435b5d
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 10.201.1.3 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/0.15
 encapsulation dot1Q 15
 ip address 10.201.15.254 255.255.255.0
interface GigabitEthernet0/0.30
 encapsulation dot1Q 30
 ip address 10.201.30.254 255.255.255.0
interface GigabitEthernet0/0.35
 encapsulation dot1Q 35
 ip address 10.201.35.254 255.255.255.0
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
router eigrp 1
 network 10.201.0.0 0.0.255.255
 passive-interface GigabitEthernet0/0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip access-list standard snmp_acl
 permit 10.201.30.100
ip access-list standard ssh_acl
 permit any log
snmp-server community NF8Y3%MC!KS RO snmp_acl
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps transceiver all
snmp-server enable traps ds1
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps license
snmp-server enable traps envmon
snmp-server enable traps flash insertion removal low-space
snmp-server enable traps auth-framework sec-violation auth-fail
snmp-server enable traps c3g
snmp-server enable traps adslline
snmp-server enable traps vdsl2line
snmp-server enable traps icsudsu
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps ds0-busyout
snmp-server enable traps ds1-loopback
snmp-server enable traps energywise
snmp-server enable traps vstack
snmp-server enable traps mac-notification
snmp-server enable traps trustsec-sxp conn-srcaddr-err msg-parse-err conn-config-err
snmp-server enable traps bgp cbgp2
snmp-server enable traps isis
snmp-server enable traps ospfv3 state-change
snmp-server enable traps ospfv3 errors
snmp-server enable traps aaa_server
snmp-server enable traps atm subif
snmp-server enable traps cef resource-failure peer-state-change
snmp-server enable traps memory bufferpeak
snmp-server enable traps cnpd
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps entity-ext
snmp-server enable traps fru-ctrl
snmp-server enable traps resource-policy
snmp-server enable traps event-manager
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps mempool
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps nhrp nhs
snmp-server enable traps nhrp nhc
snmp-server enable traps nhrp nhp
snmp-server enable traps nhrp quota-exceeded
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps syslog
snmp-server enable traps vtp
snmp-server enable traps waas
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps ipsla
snmp-server enable traps bfd
snmp-server enable traps gdoi gm-start-registration
snmp-server enable traps gdoi gm-registration-complete
snmp-server enable traps gdoi gm-re-register
snmp-server enable traps gdoi gm-rekey-rcvd
snmp-server enable traps gdoi gm-rekey-fail
snmp-server enable traps gdoi ks-rekey-pushed
snmp-server enable traps gdoi gm-incomplete-cfg
snmp-server enable traps gdoi ks-no-rsa-keys
snmp-server enable traps gdoi ks-new-registration
snmp-server enable traps gdoi ks-reg-complete
snmp-server enable traps firewall serverstatus
snmp-server enable traps ike policy add
snmp-server enable traps ike policy delete
snmp-server enable traps ike tunnel start
snmp-server enable traps ike tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps rf
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps vrfmib vrf-up vrf-down vnet-trunk-up vnet-trunk-down
snmp-server enable traps ethernet cfm alarm
snmp-server host 10.201.30.100 version 2c nf8y3%mc!ks
control-plane
banner motd ^Cotd#Welco^C
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password 7 01100f175804
 transport input ssh
scheduler allocate 20000 1000
end
Switch config:
W-SD-Admin-SG3-000#sh run
config-file-header
W-SD-Admin-SG3-000
v1.4.2.4 / R800_NIK_1_4_194_194
CLI v1.0
set system mode switch
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
default-vlan vlan 30
exit
vlan database
vlan 1,15,35
exit
voice vlan id 35
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00800f Mtitel_phone_____
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
voice vlan oui-table add 08000f Mitel_phone
no bonjour enable
hostname W-SD-Admin-SG3-000
no passwords complexity enable
passwords complexity min-classes 2
passwords aging 0
username cubs password encrypted 4084766cc943de81941d2a2df329b264b3642e84 privilege 15
username admin password encrypted d92342976d720ff38cf5dcb329be41959ab1ba6c privilege 15
ip ssh server
ip ssh password-auth
snmp-server server
snmp-server community NF8Y3%mC!Ks ro 10.201.30.100 view Default
no ip http server
clock timezone CST -6
clock summer-time DST recurring usa
clock source sntp
sntp unicast client enable
sntp unicast client poll
sntp server 10.201.30.254
ip telnet server
interface vlan 1
 ip address 10.201.30.2 255.255.255.0
 no ip address dhcp
interface vlan 15
 name Wireless
interface vlan 35
 name Voice
interface gigabitethernet1
 switchport trunk allowed vlan add 15,35
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
interface gigabitethernet10
interface gigabitethernet11
interface gigabitethernet12
interface gigabitethernet13
interface gigabitethernet14
interface gigabitethernet15
interface gigabitethernet16
interface gigabitethernet17
interface gigabitethernet18
interface gigabitethernet19
interface gigabitethernet20
interface gigabitethernet21
interface gigabitethernet22
interface gigabitethernet23
interface gigabitethernet24
interface gigabitethernet25
 spanning-tree link-type point-to-point
 macro description switch
 switchport default-vlan tagged
 !next command is internal.
 macro auto smartport dynamic_type unknown
interface gigabitethernet26
interface gigabitethernet27
interface gigabitethernet28
exit
banner login ^C
ThIS IS A PRIVATE SYSTEM This system and all related equipment are only for authorized use. Unauthorized use may subject you to criminal prosecution. Use of this system constitutes consent to monitoring for these purposes.
^C
macro auto processing type host enabled
macro auto processing type router enabled
macro auto built-in parameters printer $native_vlan 30
macro auto built-in parameters desktop $max_hosts 10 $native_vlan 30
macro auto built-in parameters host $max_hosts 10 $native_vlan 30
macro auto built-in parameters ip_phone $max_hosts 10 $native_vlan 35
macro auto built-in parameters ip_phone_desktop $max_hosts 10 $native_vlan 30
macro auto built-in parameters switch $native_vlan 30
macro auto built-in parameters router $native_vlan 30
macro auto built-in parameters ap $native_vlan 15
ip default-gateway 10.201.30.100
W-SD-Admin-SG3-000#
26 Replies 26
chrihussey
Some things:
  1. Not a fan of giving the G0/0 primary interface and IP and then creating sub interfaces below. Suggest taking the IP off the major interface and making it a sub-interface.
  2. You don't say what switch port the router connects to. What is it and does it allow all the VLANs on the trunk?
  3. You have the management IP of the switch in VLAN 1, yet the corresponding interface is on VLAN 30 on the router. These need to be in the same VLAN and if so making that the native VLAN on the trunk between the switch and router would probably be a good idea.
  4. You are connecting your PC to port 6 which looks like it is configured as a trunk. Be best if it was an access port in one VLAN.
  5. Add "login" to the vty lines on the router.
Just a start anyway. Hope this helps.
First I would like to thank you for your suggestions.
I made you suggestions in #1.
Regarding to #2 I have the router to the switch through GE0/0 to Link/ACT Gigabit
#3 I am not sure what you mean, can you show me the commands to make that happen?
#5 completed that
Thank you once again and look forward to your response.
OK, I haven't done much with the SG-300s but think I can help.
Regarding #3:
The configuration on the router has the 10.201.30.254 in VLAN 30:
The switch has the associated IP 10.201.30.2 in VLAN1
interface vlan 1
 no ip address dhcp
They need to be in the same VLAN. You have VLAN 30 set up as the default VLAN on the switch so change the switch to:
interface vlan 30
 no ip address dhcp
Then change the native VLAN of the trunk to VLAN 30. On the router:
 encapsulation dot1Q 30 native
As far as the switch is concerned, do a "show cdp nei" on the router and identify the port on the switch you are connected or check from the switch. Link/Act is not a port identifier. Once identified, I'd allow VLAN 30 to the trunk and make it the native VLAN on the switch. If you can send updated configs.
Router is connected to Port 25 on the switch.
Here are my updated configs:
Switch SG300-28PP
sh run
config-file-header
W-SD-Admin-SG3-000
CLI v1.0
ssd-control-start
ssd config
vlan database
exit
vlan database
vlan 1,15,35
exit
voice vlan id 35
no bonjour enable
passwords aging 0
username cubs password encrypted 4084766cc943de81941d2a2df329b264b3642e84 privil        ege 15
username admin password encrypted d92342976d720ff38cf5dcb329be41959ab1ba6c privi        lege 15
ip ssh server
snmp-server server
no ip http server
clock source sntp
ip telnet server
interface vlan 15
 name Wireless
interface vlan 30
 no ip address dhcp
interface vlan 35
 name Voice
W-SD-Admin-SG3-000#
Router 1941
SG3#sh run
Current configuration : 7017 bytes
! Last configuration change at 13:42:37 cst Tue May 30 2017
version 15.4
hostname SG3
boot-start-marker
boot-end-marker
aaa new-model
ip dhcp pool data
 lease 0 12
 lease 0 12
 lease 0 12
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
redundancy
 no ip address
 shutdown
 no ip address
 duplex auto
 speed auto
 no ip address
 shutdown
 duplex auto
 speed auto
router eigrp 1
no ip http server
 permit any log
control-plane
line con 0
line aux 0
line 2
 no exec
 stopbits 1
line vty 0 4
 password 7 0826434D1C1B16
 login authentication cubs
 transport input ssh
end
Thank You
Couple questions and things to try:
1- When you defined VLAN 30 on the switch as the default VLAN, did you save the config and reboot the switch? I assume you did, but just asking.
2- Can you ping across the trunk either from the router to the switch or vice versa?
3- What is the output of "sh ip int brief" on the router?
4- What is the output of the "show interface g25 status detailed" on the switch.
4- If nothing is still working try removing " switchport default-vlan tagged" from the G25 interface on the switch.
Here is my response to your questions:
1. Yes
2. I have laptop set  with 10.201.30.4 255.255.255.0 cable from laptop to port1 on switch.
Only able to ping from switch to router 10.201.30.2
Only able to ping Router to switch 10.201.30.254
3.see attach
4. see attach
5. have not touch it
So if the laptop is configured with 10.201.30.4 and is connected to port 1 on the switch, is VLAN 30 assigned to that port?
I have attach two files on status of port 1 on the switch. Saved configuration and then restarted switch after changes and status same with pinging after vlan 30 assigned to port 30.
I am now able to ping all interfaces on my router using Putty. I added telnet
to the following command:
transport input telnet ssh
Not able to ping my default-gateway 10.201.30.100
Try to change it to 10.201.1.3 and got the following message:
Only a directly connected router can be defined as the gateway.
Glad telnet is working and you can ping all the interfaces. Good to hear.
Why isn't the router (10.201.20.254) the default gateway?
What is the .100 host and to which port is it connected?
You have EIGRP configured, do you have any neighbors or a routing table? Is there a default route?
1. How did you come about 10.201.20.254 as being the default gateway?
2.  .100 is not connect to any port, it is being used for "ip access-list standard snmp_acl.  What do you recommend I change that to?
3. We use EIGRP here so I was told to include it in my setup.
1. 10.201.20.254 is defined as the default-router in the DHCP scope. That would be the network's default gateway for the hosts.
2- Little confused by this. The IPs defined in the "ip access-list standard snmp_acl" are not active IPs on the router. They are just hosts that are permitted. Unless there is an actual 10.201.30.100 device connected to the network, there would be nothing to ping.
3- OK, so EIGRP isn't being used just yet and I assume not fully connected to the network.
I changed my default-gateway on the router to 10.201.20.254. I try to change the "ip default-gateway to 10.201.20.254 on the switch and got the same message:
I have a cable from GE0/0 to switch port 1. My laptop is connected to port 25 and setting for laptop are 10.201.20.4  255.255.255.0  10.201.20.254.
Can't ping anything within putty in the switch but if I telnet while in the switch I can ping 10.201.20.254.
While in the router through Putty I can ping all interface on router and switch.
Why can't I ping in the switch?
OK I had a typo. When your laptop was IP 10.201.30.4 and connected to a port configured in VLAN 30 on the switch, its default gateway should have been 10.201.30.254. (Not 10.201.20.254).
Try that.
