Can't Console into ESW-520-24P Switch, Need help.
mhaque
We have 3 ESW-520-24P series switches.
I can not console them because by default they have a security profile attached into it for "Console Only" and It is set as "Deny".
I can't modify or delete it because it's a default security policy.
We can do console into ESW-540-24P series switches without any problems.
Can someone share any solutions to gain console access for these switches?
Any one from Cisco TAC support?
Thanks in advance.
Mansur.
David Carr
Level 6
Level 6
I am kind of confused by the questioning.  By default with these switches, you can access the console and administer the switch/ set ip address etc.  The Deny console you are speaking of, is this a restriction that has been placed on the device and now you cannot get into the device via console?
Hi Devicarr,
Thanks for your reply.
I can set the VLAN and Management IP address using the web interfaces.
But when I am trying to connect it via console it is not responding. I reset it to factory default and then found from the web control panel/interface that the switch has an "Access Authentication" under that it has a "Access Profile" and the profile has a default or built in profile attached says "Console Only" and it has a rule like "IP Source = 0.0.0.0/32 Permit = Deny".
I tried to delete or modify it even I tried to add a new rule to allow the console access but failed.
Does this switch series "ESW-520-24P" by default Console disabled when manufactured or ELSE? Please provide me your valuable suggestions.
Thanks in advance.
Mansur.
