Cant upgrade firware
jhb
Hi I'm currently running a Cisco SG300-28 28 port Gigabit Managed switch, when I try to upgrade the firmware it gives an error: copy:SW code file is over sized.
Can anybody assist?
Emmanuel
5 Replies 5
Mark Malone
what version are you coming from too ? unlike catalyst there are jump versions on these platforms that you need to go to first before going to direct to some images , you could try another earlier image first and work your way up to the newer one if its jumping through multiple images
Currently running 1.3.7.18. I cannot update to a more recent image as no matter what "interim" image I select I always get the over-sized error
I have encountered the same problem now, and my current version wants to upgrade to 1.4.0.88 1.4.1.03 or the updated version will have an error message
mipopov
Hello JHB and Hulk,
You need to upgrade the boot code also. The latest boot code is  1.3.5.06.
You can download it here:
https://software.cisco.com/download/home/283019669/type/282463181/release/1.3.5.58
Cheers,
Mike
Hi,mipopov
 Thank you for reply,I saw the process of upgrading from an older version in another discussion, and then I have successfully upgraded to the latest version. Thank you very much.
Hulk
