CBS250 - Ge Access switch to Trunk as soon as I connect the equipment
Ciscorudy
Beginner
Beginner
Hello to all,
I'm opening this thread because I have a problem with one of my switches cisco small business CBS250.
I have different VLANs configured with access ports.
Unfortunately when I connect a certain type of ehternet equipment it switches my access port to truck without any action from me.
How is it possible that connecting a network device to the port causes the access port to become a trunk?
This should not be allowed, especially since it causes problems.
Thanks in advance for your feedback
 The Auto Smartports feature available on Cisco Catalyst switches allows a port to automatically detect that you’ve attached a device it can recognize  , but it often leads to trouble , check the port configuration and disable it if found , also check the global device configuration and or you can also disable the smartport feature globally ,
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
KJK99
Beginner
Beginner
@Ciscorudy
So strange. Maybe you have the smartport feature enabled?
Kris K
Many thanks for yours answer.
Where is the feature smartport ?
 M.
Thank you for this answer.
Indeed the issue was le smartpot feature on auto.
Now it's work.
Many thanks.
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Recognize Your Peers
