CBS350-48P-4X Best Practice for using 10GB ports
crlowe
Beginner
Beginner
I just purchased 4 CBS350-48P-4X switches.  They are installed in two separate network cabinets about 30' apart, two on 1st floor and two on 2nd floor.  All have 10GB SPF+ transceiver modules in the 10GB ports.  All 10GB ports are configured as stacking and connected using Cat6a cables.  They are currently configured in a single stack ring, Master and Backup in one cabinet and Slave and Slave in another cabinet.  Would it be better to configure as 2 stacks, a Master and Backup in each cabinet, then connect the switches with the remaining 10GB ports configured as network or uplink ports instead of stacking ports?
Kasun Bandara
VIP Advisor VIP Advisor
VIP Advisor
according to your explanation, i guess you configured 2 x 10G ports from each switch for stacking and used ring topology to stacking. since you have 4 switches backplane stack traffic is distributing evenly.
also as you mentioned, you can have 2 stacks in two cabinets and configure LACP using 2 x 10G (20G port channel) ports between stacks.
if you have stacked all 4 switches, you have single management plane for all 4 switches. if you create 2 stacks , management need to do in 2 management planes.
below link also will help you to get idea about two connectivity methods.
https://medium.com/@AriaZhu/switch-stacking-vs-uplink-which-is-better-for-connecting-switches-2406c78a12a5
Good luck
rate and mark as answer i this resolved your concern
KB
Good luck
KB
Kasun Bandara
VIP Advisor
Good luck
KB
Good luck
KB
crlowe
Beginner
Beginner
Thank you.  I will leave the stacked ring configuration as is.
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Recognize Your Peers
