Cisco 3750-48ts Ios upgrade help
joaq271982
Good morning all,
I am going to start off with what I am trying to accomplish with my switch. I am using a 3750-48TS for my home lab. I am fairly familiar with cisco equipment, but have never upgraded a switch. Originally I had the switch configured with all my vlans, but I found that the stock ios didn't support ssh and i was told that I would need upgrade the ios, but with this switch I have I found that ram/flash was onboard so I had to delete the current ios.(Original image: c3750-ipbase-mz.122-25.SEE1.bin)
This part wasn't an issue and went fine. The first image file I tried to load would spite out a string similar to this: !!!!!!!!!!!O!!!!!!!!!!!OO!!!!!!!!!!!!!!!O!!!!!!!! and so on.. at it would say device was out of space (c3750-ipservicesk9-mz.150-2.SE11.bin).
I took a step back and did some research and found that the image file was most likely to large. I stepped down to the current image I have uploaded to the switch now which is: (c3750-ipservicesk9-mz.122-55.SE12.bin). Now with this image I am finding I can't log into the switch from the browser i get this message: http://<switch IP>  is requesting your username and password. The site says: “level_15_access”
In the end I am just trying to find out how to login and manage the switch from the browser and what is the most current image I can upgrade this switch to that . I am including my sho version and thanks again for any suggestions.
CoreSwitch#sho ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE12, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 28-Sep-17 02:29 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
CoreSwitch uptime is 17 hours, 27 minutes
System image file is "flash:/c3750-ipservicesk9-mz.122-55.SE12/c3750-ipservicesk9-mz.122-55.SE12.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750-48TS (PowerPC405) processor (revision M0) with 131072K bytes of memory.
Processor board ID CAT1027ZMHY
Last reset from power-on
1 Virtual Ethernet interface
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:18:B9:2E:49:80
Motherboard assembly number     : 73-9680-10
Power supply part number        : 341-0028-02
Motherboard serial number       : CAT102763ZM
Power supply serial number      : DTH10232BBF
Model revision number           : M0
Motherboard revision number     : A0
Model number                    : WS-C3750-48TS-S
System serial number            : CAT1027ZMHY
SFP Module assembly part number : 73-7757-03
SFP Module revision Number      : A0
SFP Module serial number        : CAT102681VC
Top Assembly Part Number        : 800-25854-02
Top Assembly Revision Number    : D0
Version ID                      : V05
CLEI Code Number                : CNMV300CRE
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C3750-48TS      12.2(55)SE12          C3750-IPSERVICESK9-M
Configuration register is 0xF
Leo Laohoo
Plain 3750 switch (FastEthernet access ports), do not have enough Flash space to load 15.X.
The "highest" IOS this particular model can load is 12.2(55)SE train.
Leo Laohoo
Thank you for that solution Leo. I kinda figured that would be the case. So do you have any idea about the web login? Why it is asking me for a username and password? Is that something I wont beable to get around?
Thank you for that solution Leo. I kinda figured that would be the case. So do you have any idea about the web login? Why it is asking me for a username and password? Is that something I wont be able to get around?
Web login will be using the same username/password as your CLI.
