Cisco SG200 26 Boot Loop
Anyone know how to fix a boot loop on a SG200 26 without a console?
6 Replies 6
Kasun Bandara
VIP Advisor VIP Advisor
VIP Advisor
you need to find out what is the reason for boot loop. you can try resetting switch to default config without console. if that is not success, you need to console and check the errors.
Good luck
KB
Unfortunately,  the switch resets before a factory reset can be done and the SG200 doesn’t have a console port.
it seems like hardware issue then. better request for replacement
Good luck
KB
Do you happen to know if there are jumper pins that can do a reset on the board?
sorry, i didnt tried that kind of option. also its not recommended and doing that will void the warranty.
Good luck
KB
I am unable to RMA the switch, so is there a way to “factory reset” via the onboard jumpers?
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Recognize Your Peers
