cisco sg300-10 lcli command
deresotto
Hi!
Previously srw2008 switches are used, now Cisco sg300-10 models was obtained.
It does not work with ctrl-Z command to enter the local Config (lcli)
Does anyone know the correct command?
THX: deresotto
David Hornstein
Level 7
Level 7
Hi Deresotto,
We introduced new firmware for the 200 and 300 series switches at the begining of August.
(Version 1.1 of the switch firmware.)
One thing this did was open up a supportable CLI on the 300 series switches.
So,  if you cannot see a CLI interface  on the 300 series swithes, i would suggest that you upgrade the firmware to version 1.1 ASAP.
If you have firmware version 1.1 on your 300 series switch and are in the console main menu, you should see a option called textview, which is a menu option that takes you from menu to CLI.
To go back to the menu from CLI, you would just type menu from the cli prompt.
I have added the freely downloadable 300 series  CLI manual for your reference.
have fun.
regards Dave
THX!
Try it, and tell-tales.
deresotto
