Cisco Small Business Name
sulerazak
I have a couple of SF300-24P 24-Port 10/100 PoE Managed Switches in my Network. The problem I have is that, even though I name it appropriately at System Settings via the web interface, I dont see the same name when I do  a 'Show cdp neigh' from a neighboring switch. Below is a snapshot of what I see.
6 Replies 6
Tom Watts
Hi Sulerazak, I think it depends on your software version running on these switch as well. The system name TLV if I remember correctly was not a default feature in earlier releases.
If you check the setting on the switch for the CDP properties, confirm there is a System name TLV. If it is not there then the host name will be what it is, which I am guessing that looks like some sort of unique product identifier for the switch platform.
On the newer releases of software there is System Name TLV available as a configurable feature along with the CDP version type.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hello
short answer: perform this command "cdp device-id format hostname" on SG300 switches to get them advertised hostname instead of system MAC address in CDP packets.
Yiu Kay Lee
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/CLI_300.pdf
You can change system device-id display from MAC address (default) to host name or serial number.
Yiu Kay Lee
Concentrix at Cisco
.:|:.:|:. CISCO | Yiu Kay Lee | SMB Pre-Sales | yiulee@cisco.com | Phone +1 (855) 354-7776
sulerazak
Thank You all for your response. Unfortunately, when I do a "cdp device-id format ?" at config mode, I only have options of mac and serial number as shown below. Is it that my IOS doesnt support the hostname format?
What version of firmware your SF300 switches are running ?
Yiu Kay Lee
Concentrix at Cisco
I've just confirmed and it appears the firmware is the problem. Perhaps, I need to do an upgrade.Below is a snapshot of the current firmware
