Cisco SPS2024 and CDP
Michal Bruncko
Level 4
Level 4
Hello all,
have anyone knowledge if switch Cisco SPS2024 will support CDP protocol in near future? Currently it is not CDP compilant and if there is any neighboring CDP-capable switch connected to it, this switch just broadcasts CDP frames out all other ports and receivings switches are confused with its.
rmanthey
Level 4
Level 4
Michal,
This is an older switch, so I wouldn't be able to tell you for sure, but if you are in phone support you can we can create a case and go through the process of a feature request.
Call into 1866-606-1866 to create a case for this process, you will need to be in phone support though.
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
