02-12-2018 09:14 AM - edited 03-21-2019 11:21 AM
Despite having the console timeout set for 30 minutes, an SG350-28P running firmware 2.3.5.63 is kicking me out after a few seconds to a minute or so. I've not used a stop watch, but it's definitely not 30 minutes (nor was it 10 which is the default). This happens in IE11, Chrome 63 or 64, and Edge on Windows Server 2008 R2, Server 2016, or Windows 10 Pro. Surely I'm doing something wrong. Thoughts?
07-22-2022 07:16 AM
Hello Everyone,
The new firmware for CBS switches version 3.2.0.84 has been released. Be sure to check the release notes for the full bug fix list.
A couple important notes:
Thank you everyone for raising your issues.
Best,
Corey
07-24-2022 07:46 AM
The industry standard is to use an HTTP proxy to access protected device HTTP endpoints.
This horrendous bug persists when using an HTTP proxy to access Cisco switches; HTTP header "X-Forwarded-For" has not been implemented.
Additionally the blinking "Save" configuration button no longer appears when the switch is access via HTTP proxy in the latest firmware.
07-25-2022 07:01 AM
Hi Mark,
Thanks for your feedback. I'll share it with the team and see if there is an active status bug.
01-24-2023 08:26 AM
Someone has the problem in current Chrome that the logout still takes place? As soon as I change the tab for more than about 30 seconds I will be disconnected while going back to it...
