CSB250-16p-2g vlan setup
dewin
Hi everyone,
I just purchased a CSB250 MultiLayer Switch, out of the box in VLAN 1 internet routes through all the ports. I would like my AP's in a separate VLAN and route the internet on both vlans. I setup my Switch (see attached file) through the CLI first with only access ports and then i tried it with a Layer 3 port but no internet. I get my internet through a ISP kabel router modem. ip adres 192.168.1.1 which i connect to port 16 on the switch. I can ping the vlan ip addresss and router port but if i connect my laptop to the switch i don't get internet. is give my laptop a static ip address.
Please help!
Kind Regards.
Thanks balaji.bandi for your reply!
is the cable modem youcan make any changes?
No, the cable modem is the problem (almost nothing to change)
Thanks to your input i setup my switch and i am going to set my cable modem in Bridge mode and
create a pfsense router.
Kind Regards.
balaji.bandi
if the switch acting as Layer 2, then you can use "ip default-gateway 192.168.1.1"
if you like switch to be part of routing, then ip route 0.0.0.0 0.0.0.0 192.168.1.1 will be good choice.
conf t
int ge 16
no switchport mode
ip address 192.168.1.254 255.255.255.0
no shut
ip route 0.0.0.0 0.0.0.0 192.168.1.1   ( i was hoping 192.168.1.1 is your cable modem IP address ?)
when you do the above config, from switch are you able to reach or ping 8.8.8.8 or 1.1.1.1 ?
if that is working, since your other subnet not part of network address translation, so those will not able to reach internet.
192.168.10.0/24
like add 192.168.10.0/24 for network address translation
add statc route back 192.168.10.0/24 network towards switch IP that is 192.168.1.254 ?
BB
Kind Regards.
sure and glad you found the alternative solution here.
BB
