10-14-2013 07:02 PM
Hey guys,
I'm having trouble figuring out the meaning of the bytes in Option82 that Cisco's SG300 switches send. The switch is in l3 mode, and I have dhcp relay setup and working great.
Looking at the packet captures, the switch always sends it's MAC address as the remote-id in option 82:
Option 82 Suboption: (2) Agent Remote ID
Length: 8
Agent Remote ID: 000634bdc8xxxxxx
34:bd:c8 is an OUI registered to Cisco Systems.
I'm having trouble deciphering the circuitid. The last couple bytes have something to do with the port:
Port 1:
0004007d0131
Port 2:
0004007d0132
Port 3
0004007d0133
Port 4
0004007d0134
Port 49:
0004007d0161
Port 50:
0004007d0162
But really what makes me scratch my head is the byte 'd' following the 0004007, call it the mystery digit. This byte systems to have a meaning connected to the type of device immediately connected. When I connected a computer, there is a 'd' there. When I connect an aastra phone, I get a '8'. When I connected a Ubiquiti networks AP, I got a '7'.
I can't figure out the numbering scheme for ports nor the meaning of the mystery digit. Any help appreciated!
Solved! Go to Solution.
10-19-2013 08:35 AM
Hi Jonathan with sub option 2, from your example D is the node identifier.
When seeing the variable per connection type, I would give a safe assumption it is verbose padding the sub type 1.
The verbose pad formatting for the packet should contain
sub option
length
node identifier
port type
interface number
vlan id
For normal pad format it should contain
sub option
length
circuit
length
vlan id
interface number
-Tom
Please mark answered for helpful posts
10-22-2013 05:11 AM
Jonathan, there is not documentation. Here is the break down on the example.
0004007d0133
00 - circuit
040 - length
007d-VID=125
0133-global ID
-Tom
10-19-2013 07:12 AM
Hi Jonathan, DHCP option 82 can support 2 sub options, the circuit ID and remote ID. There is not a unified definition and varies from vendor to vendor.
With the sub option 1, circuit ID there is verbose padding which inserts the node identifier which is what you are seeing.
-Tom
10-19-2013 08:11 AM
Hey Tom, first, thank you for your answer. I really appreciate you taking a crack at it.
The option82 information here is being inserted by the Cisco switch. I completely get what you're saying when you said it varies from vendor to vendor.
So in this particular case, the vendor is Cisco and I'm trying to figure out what information Cisco is sending in the option 1 field. I've figured it out it has _something_ to do with which port # the device is connected on, but the rest of the bytes are a mystery.
10-19-2013 08:35 AM
sub option
length
node identifier
port type
interface number
vlan id
sub option
length
circuit
length
vlan id
interface number
-Tom
10-20-2013 11:44 AM
Is there documentation laying around about the verbose padding format? The hex bytes still aren't making any sense.
10-22-2013 05:11 AM
0004007d0133
00 - circuit
040 - length
007d-VID=125
0133-global ID
-Tom
10-22-2013 11:27 AM
In case this helps anyone else,
Port #3:
0x0133 = 307 in base10
307 - 304 = 3
Port #50
0x0162 = 354
54 - 304 = 50
304 is some sort of magic constant it seems.
09-13-2017 08:58 PM
The SG300 uses the type 1 circuit-id format, which goes like this:
byte 1 - "1" indicates option 1 format
byte 2 - length of the circuit-id option in bytes, but it is always "4" for option 1
bytes 3 & 4 - VLAN id
byte 5 - Slot number; always "1" on SG300 switches
byte 6 - Port number; this is the SNMP ifIndex number
On the SG300 switches that I've checked, gi1 starts at ifIndex 49 and are numbered consecutively. But ifIndex numbers do not have to be consecutive.
You can find out your ifIndex to name mapping, by snmpwalk'ing the ifDescr table.
This is what that looks like:
tom$ snmpwalk -v2c -c yourcommunity my-sg300.domain.com ifDesc
IF-MIB::ifDescr.49 = STRING: gigabitethernet1
IF-MIB::ifDescr.50 = STRING: gigabitethernet2
IF-MIB::ifDescr.51 = STRING: gigabitethernet3
IF-MIB::ifDescr.52 = STRING: gigabitethernet4
IF-MIB::ifDescr.53 = STRING: gigabitethernet5
IF-MIB::ifDescr.54 = STRING: gigabitethernet6
IF-MIB::ifDescr.55 = STRING: gigabitethernet7
IF-MIB::ifDescr.56 = STRING: gigabitethernet8
IF-MIB::ifDescr.57 = STRING: gigabitethernet9
IF-MIB::ifDescr.58 = STRING: gigabitethernet10
IF-MIB::ifDescr.59 = STRING: gigabitethernet11
IF-MIB::ifDescr.60 = STRING: gigabitethernet12
IF-MIB::ifDescr.61 = STRING: gigabitethernet13
IF-MIB::ifDescr.62 = STRING: gigabitethernet14
IF-MIB::ifDescr.63 = STRING: gigabitethernet15
IF-MIB::ifDescr.64 = STRING: gigabitethernet16
IF-MIB::ifDescr.65 = STRING: gigabitethernet17
IF-MIB::ifDescr.66 = STRING: gigabitethernet18
IF-MIB::ifDescr.67 = STRING: gigabitethernet19
IF-MIB::ifDescr.68 = STRING: gigabitethernet20
IF-MIB::ifDescr.69 = STRING: gigabitethernet21
IF-MIB::ifDescr.70 = STRING: gigabitethernet22
IF-MIB::ifDescr.71 = STRING: gigabitethernet23
IF-MIB::ifDescr.72 = STRING: gigabitethernet24
IF-MIB::ifDescr.73 = STRING: gigabitethernet25
IF-MIB::ifDescr.74 = STRING: gigabitethernet26
IF-MIB::ifDescr.75 = STRING: gigabitethernet27
IF-MIB::ifDescr.76 = STRING: gigabitethernet28
IF-MIB::ifDescr.77 = STRING: gigabitethernet29
IF-MIB::ifDescr.78 = STRING: gigabitethernet30
IF-MIB::ifDescr.79 = STRING: gigabitethernet31
IF-MIB::ifDescr.80 = STRING: gigabitethernet32
IF-MIB::ifDescr.81 = STRING: gigabitethernet33
IF-MIB::ifDescr.82 = STRING: gigabitethernet34
IF-MIB::ifDescr.83 = STRING: gigabitethernet35
IF-MIB::ifDescr.84 = STRING: gigabitethernet36
IF-MIB::ifDescr.85 = STRING: gigabitethernet37
IF-MIB::ifDescr.86 = STRING: gigabitethernet38
IF-MIB::ifDescr.87 = STRING: gigabitethernet39
IF-MIB::ifDescr.88 = STRING: gigabitethernet40
IF-MIB::ifDescr.89 = STRING: gigabitethernet41
IF-MIB::ifDescr.90 = STRING: gigabitethernet42
IF-MIB::ifDescr.91 = STRING: gigabitethernet43
IF-MIB::ifDescr.92 = STRING: gigabitethernet44
IF-MIB::ifDescr.93 = STRING: gigabitethernet45
IF-MIB::ifDescr.94 = STRING: gigabitethernet46
IF-MIB::ifDescr.95 = STRING: gigabitethernet47
IF-MIB::ifDescr.96 = STRING: gigabitethernet48
IF-MIB::ifDescr.97 = STRING: gigabitethernet49
IF-MIB::ifDescr.98 = STRING: gigabitethernet50
IF-MIB::ifDescr.99 = STRING: gigabitethernet51
IF-MIB::ifDescr.100 = STRING: gigabitethernet52
IF-MIB::ifDescr.1000 = STRING: Po1
IF-MIB::ifDescr.1001 = STRING: Po2
IF-MIB::ifDescr.1002 = STRING: Po3
IF-MIB::ifDescr.1003 = STRING: Po4
IF-MIB::ifDescr.1004 = STRING: Po5
IF-MIB::ifDescr.1005 = STRING: Po6
IF-MIB::ifDescr.1006 = STRING: Po7
IF-MIB::ifDescr.1007 = STRING: Po8
IF-MIB::ifDescr.3000 = STRING: tunnel1
IF-MIB::ifDescr.7000 = STRING: loopback1
IF-MIB::ifDescr.20000 = STRING: Logical-int 1
IF-MIB::ifDescr.100000 = STRING: 1
IF-MIB::ifDescr.100001 = STRING: 2
IF-MIB::ifDescr.100002 = STRING: 3
IF-MIB::ifDescr.300000 = STRING: 2
02-06-2023 09:17 AM
Extending samplonius's answer to the SG500X by extrapolating to stacking switches is fairly straighforward. The slot number, instead of being a constant, directly corresponds to the switchunit number. The port number is still derived from the ifIndex, but is relative to the last ifIndex of the preceding switchunit. In the example below, the last port on switchunit 2 has port 1 on switchunit 3 has ifIndex 220 and the first port on switchunit 3 has ifIndex 269, for a relative offset of 49 (0x31 in hex).
IF-MIB::ifDescr.203 = STRING: gigabitethernet2/1/45
IF-MIB::ifDescr.204 = STRING: gigabitethernet2/1/46
IF-MIB::ifDescr.205 = STRING: gigabitethernet2/1/47
IF-MIB::ifDescr.206 = STRING: gigabitethernet2/1/48
IF-MIB::ifDescr.217 = STRING: tengigabitethernet2/1/1
IF-MIB::ifDescr.218 = STRING: tengigabitethernet2/1/2
IF-MIB::ifDescr.219 = STRING: tengigabitethernet2/1/3
IF-MIB::ifDescr.220 = STRING: tengigabitethernet2/1/4
IF-MIB::ifDescr.269 = STRING: gigabitethernet3/1/1
IF-MIB::ifDescr.270 = STRING: gigabitethernet3/1/2
IF-MIB::ifDescr.271 = STRING: gigabitethernet3/1/3
IF-MIB::ifDescr.272 = STRING: gigabitethernet3/1/4
vlan-9-switchunit-2-port-45 → 00:04:00:09:02:5d # ifIndex 203
vlan-9-switchunit-2-port-46 → 00:04:00:09:02:5e # ifIndex 204
vlan-9-switchunit-2-port-47 → 00:04:00:09:02:5f # ifIndex 205
vlan-9-switchunit-2-port-48 → 00:04:00:09:02:60 # ifIndex 206
vlan-9-switchunit-2-port-xg1 → 00:04:00:09:02:6b # ifIndex 217
vlan-9-switchunit-2-port-xg2 → 00:04:00:09:02:6c # ifIndex 218
vlan-9-switchunit-2-port-xg3 → 00:04:00:09:02:6d # ifIndex 219
vlan-9-switchunit-2-port-xg4 → 00:04:00:09:02:6e # ifIndex 220
vlan-9-switchunit-3-port-1 → 00:04:00:09:03:31 # ifIndex 269
vlan-9-switchunit-3-port-2 → 00:04:00:09:03:32 # ifIndex 270
vlan-9-switchunit-3-port-3 → 00:04:00:09:03:33 # ifIndex 271
vlan-9-switchunit-3-port-4 → 00:04:00:09:03:34 # ifIndex 272
