ESW-520-24-K9 and Cisco Network Assistant
wkamil123
HI,
Is this switch model ESW-520-24-K9 is supported by Cisco Network Assistant.
In the leatest release notes of CNA are supported Catalyst Express 520 Series Switches and this model WS-CE520-24TT-K9 is on the supported list.
But the mention model above is EoL and the new one is ESW-520-24-K9.
Kamil
David Hornstein
Level 7
Level 7
Hi kamil,
ESW series switches are directly supported by Cisco Conifguration Assistant (CCA) as is the CE500 or CE520 switches.
Note, as of August 2011, the 300 series switches are supported by CCA.
regards Dave
Hi Dave,
Thanks for your replay.
Yes, you are right that this switch model is supported by CCA but not by Cisco Network Assistant.
These programs are different in functionality.
The situation has become clearer, since the customer bought the Cisco Catalyst 2960 series switch.
Kamil
