Having Trouble Setting Up Management VLAN
dtheese
I have the following configured in the Web Interface of my SG200-26 (firmware version 1.4.1.3):
VLAN Management
Default VLAN Settings
VLAN Settings
VLAN ID: 1
Originators: Default
VLAN Interface State: Enabled
VLAN ID: 500
Originators: Static
Interface Settings
Port: GE4
Interface VLAN Mode: General
Administrative PVID: 500
Frame Type: Admit All
Ingress Filtering: Enabled
Port: GE13
Port to VLAN
VLAN ID equals to: 1
Interface Name: GE4
VLAN Mode: General
Membership Type: Excluded
PVID: Unchecked
Interface Name: GE13
VLAN Mode: General
PVID: Unchecked
VLAN ID equals to: 500
Interface Name: GE4
VLAN Mode: General
Membership Type: Untagged
PVID: Checked
VLAN Mode: General
PVID: Checked
Port VLAN Membership
Interface: GE4
Mode: General
Administrative VLANs: 500UP
Operational VLANs: 500UP
Interface: GE13
Mode: General
After configuring this much, I have no problem communicating with the switch. My computer is connected directly to port 13 of the switch.
I then try to set the Management VLAN as follows:
Administration
Management Interface
IPv4 Interface
Management VLAN: 500 (was previously 1)
As soon as I apply this, I lose connectivity to the switch. This gives me these questions:
  1. Why did I *not* lose connectivity to the switch when I moved the port I'm connected to (port 13) to VLAN 500 while the Management VLAN was 1?
  2. Why *did* I lose connectivity to the switch when I set the Management VLAN to 500, matching the VLAN of the port I am connected to (port 13)?
  3. What is the proper sequence of steps to follow when configuring a Management VLAN? I ask this because you cannot, on the same screen, simultaneously 1) set the Management VLAN and 2) move to the new Management VLAN the port to which you're connected.
Dave
