03-25-2023 02:43 AM
hi, i have a priblem in connecting antminers only 4 come online and if i remove this 4 then the other 4 online and i take new ips of 1 gbps then i connect more 4 and i have 50 pic and i want to connect to 1 isp can u suggest any option or metherd
Solved! Go to Solution.
03-25-2023 01:09 PM
Hi there,
From your description it could be that you have a very small DHCP pool which can only accommodate four hosts, or perhaps you have a very restrictive NAT/ IP ACL which permits only four IPs from the 'inside' network. Ideally we really need to see that configurations of the devices you are connected to.
cheers,
Seb.
03-25-2023 01:09 PM
Hi there,
cheers,
Seb.
03-27-2023 06:27 AM
how to do this
setting little detail
03-27-2023 01:55 PM
Hi there,
Can you share the config of your network devices in question and we can comment on what needs adding/ adjusting.
cheers,
Seb.
03-25-2023 06:29 PM
