How can I delete language file from SG350X-48P?
rychetsky
SG350X-48P, fw: 2.5.7.85
I cant choose file - Administration/File mngmt/File Directory/Localization/File - it is disabled.
Where is the problem?
Michal
8 Replies 8
Martin Aleksandrov
Do you have the language pack installed? You are trying to select/switch to a language or delete the language pack?
Yes, language packs are instaled:
[cid:image001.png@01D7BED7.AC6B7AD0]
[cid:image002.png@01D7BED7.E0442F50]
Any idea?
Images:
You can simply delete the language localization file in the flash using the command delete localization command. Please refer to page 433, section 18.9 Delete.
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350xg/cli_guide/CLI_Tesla_SG350X_SG350XG_2_2_5.pdf
Hi Martin, thank you for your answer but I traied it before I made my first post.
Delete file it's not possible:
1. command delete localization doesnt exist
2. simple delete file from flash not permitted
thx Michal
Michal,
It is there. You will first need to go to the flash and then execute the command i.e. cd flash://. Please see the example to which I referred in the above guide.
Hi, I traied both way (with absolut and relative path URL) to delete files
Admin guide examle:
Try the following one as an example:
switchbf1705#no boot localization
Delete localization file(s)? (Y/N)[N] Y
18-Oct-2021 17:36:10 %HTTP_HTTPS-N-7ZFILEREM: SVNZIP localization file CBS350_LANG_zh_CN_3.1.0.59.lang was removed
18-Oct-2021 17:36:10 %HTTP_HTTPS-N-7ZFILEREM: SVNZIP localization file CBS350_LANG_ja_JP_3.1.0.59.lang was removed
switchbf1705#
this should also delete the localization file
