08-08-2012 10:12 AM
We have acquired a cisco sge 2010 to replace our distribution switch. I set up the 802.1X network. Everything works great except I can not find how to enable 802.1x with 'Wake on LAN' on this kind of switch. Do you have an idea?
On catalyst I saw that it was sufficient to activate this control "authentication control-direction {both | in}"
Except that it seems not to exist on this switch. Is there another way to enable 802.1x on WoL without using this command?
Or how to allow the magic packet (WoL) on a tagged port by unauthorized 802.1x?
Thank you in advance
Hervé
Solved! Go to Solution.
08-08-2012 03:53 PM
Hi Herve, this is unsupported.
-Tom
08-08-2012 01:19 PM
Not idéa ?
How 802.1x Unidirectional Controlled Port ?
08-08-2012 03:53 PM
-Tom
08-09-2012 11:42 AM
Ok merci, avez-vous une idée de comment puis-je autoriser le WoL sur un port controlé par 802.1x ?
08-09-2012 11:34 PM
Not idéa ?
