how to stop srw/sge sending 239.255.255.250.1900: UDP
smugas1975
Beginner
Beginner
SRW / SGE switches are sending packets like this below:
IP 172.16.57.100.1900 > 239.255.255.250.1900: UDP, length 296
IP 172.16.57.100.1900 > 239.255.255.250.1900: UDP, length 313
(a discovery message to the multicast address 239.255.255.250 on port 1900 via the UDP protocol)
Can this behaviour be disabled ?
alissitz
Enthusiast
Enthusiast
It looks like this is for uPnP.
This is normally coming from a windows machine, are you sure that it is coming from the switch?
For the switch, here is an admin guide:
http://www.cisco.com/en/US/docs/switches/lan/csbms/srw248g4p/administration/guide/SRW224G4P-248G4P_User_Guide.pdf
These are platform specific, however you basically need to disable upnp if it is a bother to you.  It is harmless for the switch to send however if you simply want to ignore it.
HTH,
Andrew Lissitz
alissitz
Enthusiast
Enthusiast
HTH,
Andrew Lissitz
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Recognize Your Peers
