i need supports for cisco switch SLM224P
cindy toy
Level 7
Level 7
(This question was originally posted as a document and was copied over here.  The original question is located here: https://supportforums.cisco.com/docs/DOC-23120)
dear Eng
i need supports for how can config SLM224P with UC540
regards
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
Tom Watts
Hi Abdulelah, the older SLM switch will need all manual configuration. If you're using the typical vlan 1, vlan 100 then the expected configuration of the switch would consist of the following-
  • The link between the switch and UC configured as 1untagged, 100tagged
  • The link between the telephone and the switch configured as 1untagged, 100tagged
  • The links connecting the phones should have spanning-tree portfast enabled
Please keep in mind the old SLM switches do not support auto voice vlan, LLDP, CDP, etc. A SX200, SX300 or SX500 switch would be a more appropriate device for a UC deployment as the SX200 and SX300 are supported by CCA and is basically a zero config deployment as far as the switch is concerned.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
