12-01-2015 11:18 PM
Hi Team,
I have Cisco SG300-52 52 Port Managed Switch. Does the switch support Inter-VLAN Routing with the help of a Layer 3 Device? If yes, please help me with the configuration.
Sri Charan M S
12-02-2015 03:31 AM
yes its support L3 but it needs to be turned on from system section as out of the box there layer 2
once you enable it for layer 3 it will support intervlan routing automatically once the vlans are created
heres the admin guide its pretty easy to follow
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
12-02-2015 04:01 AM
I have enabled L3 and i'm able to create VLANs, but I'm unable to route between two VLANs...
Is it possible to route between 2 VLANs with only SG300 switch with L3 enabled?
12-02-2015 04:10 AM
yes its possible its a complete L3 device
have you enabled the vlan interfaces given them ips etc and assigned a local port to that vlan so it goes up/up, can you console in and ping from vlan interface to vlan interface that will confirm if its definitly an intervlan issue
vlan 1 vlan 2
ping 10.1.1.1 source 10.11.11.11
12-04-2015 05:23 AM
Hey Mark.
I have enabled the vlan interfaces, given ips assigned ports and i realized my acl's were wrongly configured. Thanks for the help..
12-04-2015 05:24 AM
ah glad you got it sorted :)
01-26-2017 05:37 PM
Hi, could you give me the recipy please? I have the same issue. Thanks a lot
