06-01-2012 07:07 AM
I am trying get inter vlan routing to work on a DF 300 - 24 port switch. I have an existing company network on 192.168.111.0 and want to create a vlan on 192.168.1.1 that can talk to 192.168.111.0. I have enabled layer 3 routing on the switch via console and also provided the ip routing command. I have the following VLAN's:
VLAN1 - Default 192.168.111.0
VLAN2 - 192.168.1.0
I have enabled DNS and provided my two DNS servers 192.168.111.82 & 192.168.111.212.
I have set the VLAN1 interface to 192.168.111.217 and VLAN2 interface to 192.168.1.1.
Ports FE1 - FE15 are set to access ports and assigned to VLAN1 (untagged)
Ports FE16 - FE24 are set to access ports and assigned to VLAN2 (untagged)
I have set a default route for the switch to 0.0.0.0 0.0.0.0 192.168.111.254 (Draytek 2600 router). I have connected a computer (A) to VLAN1 port FE3 and a computer (B) to VLAN2 port FE16. I have set Computer A default gateway to 192.168.111.217 and its IP address to 192.168.111.94. I have set Computer B default gateway to 192.168.1.1 and IP to 192.168.1.2.
Computer A has access to Mdaemon, file server via network drives but no internet (cannot ping google) and can ping computer B and RDP onto computer B.
Computer B can ping computer A and RDP onto computer A but does not have access to the company network i.e MDaemon, file server etc. It also cannot access the internet.
From the console I can ping www.google.co.uk and all ip addresses in the company network i.e. 192.168.111.82 (DNS server). I dont understand what i am doing wrong and have been banging my head for days just staretd a new job and desperatly need to get it working so any help would be greatly appreciated
If I scan computer A wirh wireshark the internet starts working wheird!
Configuration show below:
switch7c0a71#show run
vlan database
vlan 2
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
interface vlan 2
exit
interface vlan 1
ip address 192.168.111.217 255.255.255.0
exit
ip route 0.0.0.0 0.0.0.0 192.168.111.254
interface vlan 1
no ip address dhcp
exit
bonjour interface range vlan 1
hostname switch7c0a71
no passwords complexity enable
no snmp-server server
interface fastethernet1
switchport mode access
exit
interface fastethernet2
exit
interface fastethernet3
exit
interface fastethernet4
exit
interface fastethernet5
exit
interface fastethernet6
exit
interface fastethernet7
exit
interface fastethernet8
exit
interface fastethernet9
exit
interface fastethernet10
exit
interface fastethernet11
exit
interface fastethernet12
exit
interface fastethernet13
exit
interface fastethernet14
exit
interface fastethernet15
exit
interface fastethernet16
switchport mode general
switchport general allowed vlan add 2 untagged
exit
interface fastethernet17
exit
interface fastethernet18
exit
interface fastethernet19
exit
interface fastethernet20
exit
interface fastethernet21
exit
interface fastethernet22
exit
interface fastethernet23
exit
interface fastethernet24
exit
interface vlan 2
name Development
exit
Solved! Go to Solution.
06-18-2012 06:32 AM
Can you ping 8.8.8.8? If not, i recommend a tracert to 8.8.8.8 to see how far you can get.
06-18-2012 07:02 AM
Hi Robert,
I have run a tracert on 8.8.8.8 and I get the following:
1 * * * request timed out
2 * * * request timed out
3 * * * request timed out
etc
Kind Regards
Richard
06-18-2012 07:06 AM
Hi Richard,
What IP from your ISP are you pinging thats working?
Since you're able to ping the draytek from the vlan 4 computer, and the reverse (and access the LAN), I think your switch is config'd properly at this point, and its something with the draytek.
Best,
David
06-18-2012 07:22 AM
Hi David,
I have taken the WAN IP address from the WAN status page of the router, I dont want to post the IP address though for obvious reasons.
Kind Regards
Richard
06-18-2012 07:26 AM
Hi David,
I did a tracert on the ISP IP address and got the following:
1 * * * Request timed out.
2 <1 ms <1 ms <1 ms ISP IP ADDRESS
regards
Richard
06-18-2012 07:28 AM
Thats your public ip, correct? can you ping your ISP's default gateway?
Best,
David
06-18-2012 07:32 AM
Hi David,
How do I find out the ISP's default gateway.
Kund Regards
Richard
06-18-2012 07:34 AM
Hi David,
Just found it, I am unable to ping the GW IP Addr displayed on the router status page.
Richard
06-18-2012 07:35 AM
Hi David,
I also cannot ping the primary and secondary dns servers for the ISP.
Richard
06-18-2012 08:17 AM
Richard,
I think that you should try and get in touch with Draytek support or follow up on that end.
Check out this thread:
http://www.network-builders.com/draytek-vigor-2600-multi-nat-dmz-vlan-question-t34149.html
I emailed Draytek directly and got the following response:
a. The Vigor can only deal with one subnet. You could still use the
Vigor VLAN facility to separate the ports but you'd need two more
devices to act as the gateway for the other two subnets.
My suggestion prior to reading that would be to set up the subnet on the draytek (if the draytek has multiple interfaces) or use the draytek router to create the vlan, but you may be running into the limits of the router.
Best,
David
06-18-2012 08:34 AM
Hi David,
I have found this on the draytek router:
