01-09-2017 04:54 PM
just got a new SG350-28P and I am missing the point "Bandwidth" in the QoS menu, even in the SG200 its there..
..is the SG350 missing this function or is it just hidden somewhere else?
Alfred
Solved! Go to Solution.
01-11-2017 12:44 AM
Hello Alfred,
I am sure you have this option available in your SG350 switch.
Just please make sure that you enabled the Advanced view in the Display Mode in top right corner of your Web Access GUI of the SG350. After changing the view to Advanced, you should be able to access the Bandwidth management page in QoS section.
Also after enabling Advanced view, just do not get scared from amount of additional options that will appear! :)
Have a nice day and let me know if you still need any assistance!
Adam
01-11-2017 12:44 AM
Hello Alfred,
Adam
01-12-2017 12:59 AM
Hello Adam,
thank you for your answer, that is what I was looking for!
Alfred
