11-01-2024 01:43 PM
Hi community,
I run this switch and try to set the IP based ACL rules for switch vlan’s. While I got rules working via ACL, ACE and ACL binding (vlan), I need to add many more ACE entries, and the GUI seems to have some limit to display those ACE’s. If I add more than 24, it won’t display them.
My firmware version is 3.3.0.16.
My few questions are:
Is there a way to achieve it via SSH?
Is this a GUI bug/limitation with 24 lines?
For an SSH method, where can I find commands for it?
Thank you.
11-01-2024 02:06 PM - edited 11-01-2024 02:07 PM
This device have SSH but it is very limited.
As per the administration guide it supports up to 1K ACE. What you are saying is, you can not add more than 24 ACE or you can not see all of them in the page?
11-01-2024 02:11 PM - edited 11-01-2024 02:45 PM
Yes, I cannot see them on the page, when I add it, it doesn't complain but won't display new ether.
I tried in Chrome latest version, I disabled all blocking plugins, maybe I should try Edge or other browser?
11-01-2024 02:15 PM
If you can test with different broswer it would be nice. Apparently, there is not limitation on the switch side.
11-01-2024 02:17 PM
Ok, I will try over the weekend.
