07-04-2014 02:51 AM
I wanted to know if the Microsoft Network Load Balancing can also be configured on the switch SG-500? and if so, how?
07-07-2014 11:57 PM
From everything I have read about this service, it is independent of hardware, the configuration is all done on the servers themselves.
Source I used: Microsoft Network Load Balancing Technical Overview
The section on Ease-of-use talks about there being no hardware changes required for this to work.
Hope that helps and thank you for choosing Cisco,
Christopher Ebert - Advanced Network Support Engineer
Cisco Small Business Support Center
*please rate helpful posts*
07-09-2014 08:39 AM
07-09-2014 12:30 PM
From looking over your document the unicast solution won't be a problem, but with the multicast setup the issue you run into is needing to set the same MAC address statically on two different interfaces (mac−address−table static 0100.5e11.1111 vlan 200 interface fa2/3 fa2/4). This is something you cannot go on the SG500s.
I am just going off of these documents, since I cannot really test this here in my lab, but I would say if you want to set it up like that you would need an enterprise switch.
Christopher Ebert
