09-26-2018 11:43 AM
Good day all.
I've been tasked with creating multiple 10G connections between two SG350XG-24F switches at two different sites connected via single mode fiber. So far I've created a trunk link between the 2 in order to carry over some DIA links and that's worked fine. Eventually the higher ups want to be able to have multiple 10G links for different services between sites, thereby allowing different 10G paths based on each port on the switches.
I've been thinking that if I were to connect the switches together via multiple ports ( SwA Te1/0/1 to SwB Te1/0/1, SwA Te1/0/2 to SwB Te1/0/2, SwA Te1/0/3 to SwB Te1/0/3, etc), STP would shut down ports in order to break the loops. I've considered using the ports in layer 3 mode by issuing the "no switchport" command thus eliminating the STP issue.
Below is a drawing of how I imagined it. Does this make sense? Is it possible or best practice?
Solved! Go to Solution.
01-17-2019 04:10 PM
Just in case anyone else wanted to ask this, I eventually used access links to connect the two switches and then created different MST regions containing each link thereby preventing STP from shutting one down. In each region, one link remained active and a single vlan was assigned to each region. This allowed 3 separate links to be up and complete isolation of the traffic going across those links.
09-26-2018 11:48 AM
In this case, why not consider creating a Port-channel, so you can bundle them in to big pipe, if one of link fails still you have 2 links till serve.
Switch A -----Port-channel ---- Switch B
09-26-2018 10:01 PM
01-17-2019 04:10 PM
