What is the best scenario to tie together (2) sg300-28pp and 5 sg300-10pp?
*Have set ip for each and upgraded all to latest firmware.
*One switch will be directly connected to VPN/Firewall which is connected to ISP modem.
*Need best suggestion for connecting the other 6 switches to main switch.
*should I leave in layer 2 mode?
*just leave default vlan? No need at this point to use multiple vlans.
*do I need to set dns to our Domain controller which is also DNS / what about gateway? (set on each switch?)
*straight runs to each switch from main switch?
Thanks for any help or suggestions.
